TH350 giveing me hell
Here is the problem. Manualy shifting it. 1st fine, 2nd it just revs to about 4grand then it will kick in..sometimes at a lower rpm it will kick in. 3rd fine. Put it in D 1st fine...then the car starts bucking trying to find second. I don't have my TV cable hooked up..isn't that just for downshifting? Is my tranny bad? torque converter bad?
th350 has no tv valve or cable. i ithnk you're confusing the kick down with tv cable, that would be for downshifting into "passing gear". i'd check or have the line preasure checked and the modulator.
gixxer92
May 18, 2017 11:20 AM
