i wanna put a 350 in to a 5 spd or vice cersa
Old Aug 7, 2003 | 10:49 AM
Bajram's Avatar
Car: 91 z28 1le
Engine: 357
Transmission: 96 - 6 spd
has anyone done this to there camaro changed a 305 tpi 5spd to a 350 tpi i wanna know what u need i know the injectors are diffrent as well as the block but i dont know what to do computer wise to i get a 350 computer or a keep my 305 computer and use a custom burned prom to run it? its a 91 305 car 5 spd im planning on buying my own laptop as well as a coneector what else do u ineed to be able to plug my laptop in a burn my own prom or chip and what kind of chip do i need t odo this as well as coneectrs?
Old Aug 7, 2003 | 01:42 PM
2.73's Suck's Avatar
Car: 1985 Mustang GT
Engine: hamsters
Transmission: a hamster wheel
read this article about burning chips and scanners
https://www.thirdgen.org/newdesign/tech/promintro.shtml
and to change to a 350 youll need injectors or I think you can get away with an adjustable fuel pressure regulator if the 350 is pretty stock. youll need the 350 knock sensor too. everything else is bolt up, good luck.
BRoss99
Aug 10, 2025 05:08 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Dquickshift
Aug 12, 2015 06:21 PM
