WCT-5 Clutch Question
Old Aug 9, 2003 | 02:30 AM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
I replaced my clutch less than a year ago with a cheap brand special from Autozone. It never held very well and it's already worn out. I've been looking at the Centerforce Dual Friction clutch and it seems that the DF161056 is the replacement that centerforce calls for. Here's my question: The Centerforce catalog also lists a DF161911 which has a slightly bigger o.d. of 10 3/4". Can I use the DF161911 for my application? TIA for your help.
Old Aug 9, 2003 | 07:03 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.
The 161056 will work fine.
Old Aug 9, 2003 | 12:05 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
yeah i agree with rb, and you'll love that clutch, i had an autozone before and it kept slipping when i mashed the pedal, ripped that out, threw in the centerforce d/f and it's like night and day
Old Aug 9, 2003 | 09:37 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Okay, thanks for the responses. The reason I had asked was someone has the 911 clutch for sale on eBay for $200. Could've saved a few bucks. I'll go ahead and grab the 056 for $250.
Old Aug 9, 2003 | 11:52 PM
TexasLT1's Avatar
Car: '92 RS
Re: WCT-5 Clutch Question
Haha, I did that too at first. After the second one in a year I said screw it and go a Dual Friction. Best decision I ever made. 20K miles later and lots of racing and still grabs perfectly everytime.
Old Aug 11, 2003 | 11:21 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
The 10.75" is a `vette application clutch and yes it can be used. It works on the stock 153 tooth flywheels in third gens. I know someone running one on an 86-92 f-body flywheel and he's using mechanical linkage in a g-body.
RB,
86Z,
Research before you post. Thanks.
-Matthew
Old Aug 11, 2003 | 08:53 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Thanks for the response, Matthew. Unfortunately, the auction closed yesterday, otherwise I would have simply called Centerforce. I knew that it was a vette application from the chart on their website. Further, I read I don't know how many threads in search of an answer... Sorry I didn't find a definitive answer before asking here.
I can appreciate the sentiments concerning research, but sometimes people are a bit quick on the draw with the "Research before you post" comments IMO.
Anyways, thanks again for the response.
Drone358
Sep 1, 2015 02:50 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
