700R4 Doesn't Like Park
Old Aug 11, 2003 | 10:58 AM
91FirebirdBabe's Avatar
Car: 1991 Pontiac Firebird
Engine: Holley Carb'd 350
Transmission: Auto 4-Speed w/Overdrive (THM 700R4)
My 700R4 doesn't like Park. When I put it in park the car still rolls. I have to slam it in to park to get it to take. Any suggestions? Do I just need to get it rebuilt?
Old Aug 11, 2003 | 11:09 AM
83crossfireZ28's Avatar
replace/adjust your shifter cable...
look under the car at the tranny pan on the drivers side... youll see a little bracket with a cable coming down and then parralell with the ground and it attaches to a little lever on the transmisison... check and see if it has any play in it back and forth... mine did because the plastic thing on it was broken where it bolts onto the lever....
try loosening that nut where it holds the cable onto that lever, put the car all the way in park on the shifter, and push the lever on the transmission all the way forward, then put the nut back on and tighten it... if it still wont go into park, go to the chevy dealer and get a new cable... not hard to install, they cost about 40$. and my shifter works like brand new now
Old Aug 14, 2003 | 02:04 PM
thanks for info
BlueIroc-Z
Jun 9, 2019 03:22 AM
Kevin91Z
Southern California Area
Sep 16, 2015 03:00 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
killer777
Aug 8, 2015 02:47 PM
