What else could it be??
Old Aug 12, 2003 | 02:15 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
Could the higher stall torque converter cause the car to not move in overdrive?
I went from stock 90 l98 tq cvntr to a 2400-2600 stall. Should that have any bad effects with stock ecm? Help..
what else can this be? this is the second transmission with the same problem....also 2nd torque converter.????
Old Aug 15, 2003 | 06:34 AM
EvilCartman's Avatar
Car: '82 Z28
I've got a 3000 stall and the car still moves on level ground at idle. (rolls back on hills though lol) You only say it doesn't move in overdrive, what about the other gears? What happend with the other transmission and converter? Checked the fluid level?
Old Aug 15, 2003 | 11:59 AM
Car: 1990 Iroc-Z
https://www.thirdgen.org/techbb2/sho...hreadid=195967
the story is there...
