how to tell what stall converter u have?
Old Aug 13, 2003 | 06:38 PM
icebird_1981's Avatar
the subject is my question? is there anyway to find out if its stock or has been replaced?
Old Aug 13, 2003 | 06:39 PM
wow wrong board my bad. sry
Old Aug 13, 2003 | 08:29 PM
Mad-Mic's Avatar
Car: 87 Vette 85 TA 82 Z/28
Engine: 3 - 350's 388 400
Transmission: 2-700R4's 1 T56 Setup!
Axle/Gears: 2.59's 3.42's 3.73's
hold the brake for all your worth and slowly press on the gas. you will feel the rear end load up and actually raise up some. when the tires start to barely spin over that is the limit of your stall. at your limit is what stall speed you have. if your stall is stock i would say 1600 to 1800 max rpm.
Old Aug 13, 2003 | 09:02 PM
thanks alot!
Old Aug 18, 2003 | 11:09 AM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: 700R-4
ok so call me dumb but i want to learn, what does the higher RPM stall do for you. i'm very interested in this and have never asked but now i am so all help is appreciated!
Old Aug 18, 2003 | 04:52 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
most stock 700 convertors are rated @ 1397 RPM.
Old Aug 23, 2003 | 02:27 AM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
A higher stall speed will allow the car to launch at a higher rpm, As opposed to taking off at an idle. Gets you rolling quicker, helps get the engine in the power band. Did that meake any sense? Sorry I'm going to bed.
Old Aug 23, 2003 | 04:15 PM
hot86z-28's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
yes makes lots of sense, and come to think of it i think i have heard that before. but thank you.
Old Aug 23, 2003 | 06:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's the limit of your brakes, not the actual "stall" speed.
Put the park brake on first, that may help hold the car. Or, put it up against a curb and try it (just make sure you don't jump the curb).
Higher stall allows the engine to get into its powerband. If it is already in its powerband with the converter you have, higher stall wouldn't be beneficial.
There is also a "torque multiplication" aspect of higher-stalling converters, but I'm not prepared to explain that (mostly because I frankly don't understand it).
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
amcnellis
Sep 16, 2015 04:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
