non-wc t-5 tranny problems
Car: 84 Trans Am Ws6
Engine: 305 LG4 "H.O."
Transmission: wc t-5
my transmission has problems when I try to power shift, it won't do it without grinding gears, basically in order not to grind gears, I have to wait a few seconds after pushing in the clutch and taking out of gear before I ease into the next gear, and I was wondering if their is any adjustment for the clutch? or what could be the problem, if it might be a bent clutch fork, or bad hydraulics, or even just that my tranny is in need of a rebuild. I tried bleeding the clutch it helped a tiny bit but went right back after like a week.
thanks in advance for you help.
btw
I have a new site with message board for those who are interested, there is a thirdgen section as well as others.
check it out if you would like.
http://68.113.6.65 it's uncensored no language filters or regulated content.
btw
Car: `86 SS / `87 SS
If it's doing it in all gears you have a clutch disengagement problem.
Bleed it, look for leaking at the master & slave. Search a bit; this has been gone over. Your trans. is likely fine, but a synchro is not designed to slow down a pressure plate, flywheel, and crankshaft, just a flywheel, input, countershaft, and gear.
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
