Car shakes below 1500 RPM
Old Aug 15, 2003 | 10:51 PM
trans92's Avatar
Car: 1992 Trans AM
Engine: LB9 305 TPI
Transmission: 4L60
I have a 92 automatic transmission TA. The problem I am having is when I drive my car in overdrive or drive gear below 1500 RPM, my car shakes, but the moment I go beyond 1500, it stops, sometimes I have to change my gear and go to the 2 gear to achieve higher RPM in low speed so that my car dosent shake. Anybody know why this happens, my roommate who has a 1988 camaro has a similar problem and he thinks its the torque convertor lockup thats messed up or somethin, can anyone help??
Old Aug 16, 2003 | 08:00 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
trans92,
Nice car. It sounds like your convertor could be not unlocking correctly or you have bad plug wires. Sometime is tough to tell. One quick way to tell if its the convertor is unhook the 4pin connector on the transmission, that will prevent it from locking up. Go drive it if it still does it your problem is elsewhere.
Old Aug 18, 2003 | 01:16 PM
83_1/2 L69's Avatar
Car: 83 Z-28 (Original owner)
Engine: 305 CC-carb
Transmission: Richmond 6-speed, Rear:3.73
I had same problem. CAUSE: Bad sparkplug!
Old Aug 18, 2003 | 01:48 PM
mjpell's Avatar
I had a similar problem in the past and it was a bad spark plug. Strange, I know...
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
specialized
Jun 18, 2022 09:26 AM
kah992
Aug 19, 2015 02:55 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
hokis
Aug 9, 2015 03:57 PM
