Valve in TH700 causing lock-up / converter failure? HELP!
Old Aug 18, 2003 | 01:48 PM
joatrash's Avatar
Well, I've been calling mechanics all day. I stated in a previous post that my tranny keeps wanting to DRIVE, even in Park and will usually stall the car if I stop. It shifts fine while driving, but hassles me when idleing. This is the info I got:
Mechanic #1: "Your converter is screwed and you have to do a complete rebuild" Cost: about 1300 dollars (you read that right...this is in Europe...)
Mechanic #2: "Your converter is screwed but you DON'T need a rebuild, just a good cleaning" Cost: about 800 dollars
Mechanic #3: "It probably isn't your converter, but a VALVE in the tranny oil pump is sticking...but I do have a converter lying around in case it should be that" Cost: about 200 dollars to fix the Valve (with labor) and 200 dollars (+labor) if its the converter.
OK...so can anyone around here tell me if a sticking valve can actually be at fault? All the mechanics seemed knowledgable and I'm not getting any bad vibes from anyone. I'm thinking maybe I should give #3 a chance...he should be applauded for not jumping into the most expensive solution right away, and he WAS recommended from two sources...
What do y'all think?
1992 Trans Am
May 10, 2023 07:19 PM
deracer
Apr 11, 2016 12:04 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
crazynights
Aug 21, 2015 06:53 AM
gwade12
Aug 8, 2015 08:17 AM
