ES Trans mount question...
Old Aug 19, 2003 | 06:53 PM
Opha's Avatar
just wondering if the Energy Suspension Trans mount is a direct fit from the trans to the cross member or if i still need the secondary mounts and plate. im getting the ES mount tomorrow, but my secondary mounts..the rubber ones are torn to all hell. And i dont know if ES makes them or if i can find some after market poly ones. Can someone let me know, thanks.
Old Aug 19, 2003 | 09:07 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
what secondary mounts? There's 1 rubber trans mount that goes between the trans and the crossmember and nothing else.
Anyway, the ES mount is a direct swap for the stock one except that you have to use their bolt, which is a tad too big to fit through the hole in the crossmember, so you'll need to grind the crossmember hole a tad bigger. Piece of cake.
DO NOT use the "preload" spacer they include with the mount. It'll goof up the pinion angle and could cause a vibration.
Old Aug 20, 2003 | 08:44 AM
82camaro's Avatar
Car: 82 camaro SC
Some cars have the secondary mounts. From what I've seen it varies on which ones get them. I have them. ES makes the secondary tranny mounts you need.
A quick search on summitracing.com....
ENS-3-1109G
Bushing, Secondary Transmission Cross Member Mount, Chevy 1982-92 Camaro, Black
$17.99
Old Aug 20, 2003 | 08:41 PM
Opha's Avatar
So i can just throw out the secondary mounts and pop in the ES mount... sounds like what i was wanting to do anyways. Sounds like it would be a much better set up, transmission directly connect to the crossmember.
Old Aug 22, 2003 | 10:10 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
........... or get a crossmember without those goofy secondary mounts at the junk yard for $5 and eliminate them all together. cheaper too . can this be done on the 82's?
Old Aug 22, 2003 | 11:20 AM
82camaro's Avatar
Car: 82 camaro SC
82's have a different crossmember and mounts at different locations in the subframe. Not sure what you are saying Opha....the mounts I listed don't eliminate the secondary tranny mount. They are just replacement ES bushings that replace the existing worn out rubber ones. You still need the primary mount and secondary mount...
Old Aug 22, 2003 | 10:11 PM
Opha's Avatar
yeah, with the way it's set up i will need to use the secondary mounts. Kinda sucks, but when i get the money im just going to get a new torque arm for the trans so it fits perfectly. I tried to jimmy rig it with out using the secondary mounts, and i can feel the trans move when i shift and i know that's not good. So i guess i'll just run down to Summit tomorrow and pick them up. It's nice being 20 min from Summit and about 30 from Jegs. Prob the only good reason to live in Ohio.
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
