700r4 won't shift
Old Aug 20, 2003 | 12:04 AM
Sinister_RS's Avatar
700r4 won't shift
I have a 92 RS and it won't shift out of first gear. It goes into reverse and drive fine but it won't get out of first it just keeps reving up. it takes off like normal too. I checked the fluid and the throtle linkage and the kickdown cable and they seem fine. Also my speedometer stop working so i don't know if that would have anything to do with that or not. If anyone can help that would be great. Thanks
Old Aug 20, 2003 | 01:38 AM
Pro Built Automatics's Avatar
If this happened all at once, it is the governor gear, broken or stripped. Replace the gear, and your shifts should return.
Old Aug 21, 2003 | 12:22 AM
Yeah it happen all at once. I was driving down the street and it just reved up like it went into neutral. I'll look at what you said. Hopefully thats it. Thanks for the help
Old Aug 21, 2003 | 12:44 AM
I forgot to ask you how do you check it and if its broken how do you change it?
Old Aug 21, 2003 | 06:36 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The governor is under the rounded cover, drivers side toward rear of trans. Pry/pop cover off and slide governor out. Gear is on the end of it.
RBob.
Old Aug 21, 2003 | 09:02 AM
Ok cool, thanks alot.
Old Aug 30, 2003 | 11:11 PM
82RECAROTA's Avatar
Hotrodboba400
Dec 10, 2019 07:07 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
