T-56 Question (one of many)
Old Aug 26, 2003 | 09:11 PM
IrocindatZ's Avatar
Car: 1989 IROC-Z
Engine: 350 TPI w. Bolt_ons
Axle/Gears: Dana 44 3.73
Hey guys, this will be my second of many question i am probably going to be asking in reguard to my 700r4-t-56 transition....My question is this do i need any bolts for the donor car in order to bolt up the trans of the hydros or anything to that effect, i got the trans and everything but i got no bolts or anything like that...
thanks
James
Old Aug 27, 2003 | 05:51 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Oops.
You need lotsa bolts. Here are the ones I can think of off the top of my head.
Flywheel bolts (your old flexplate bolts are too short.)
Tranny-bellhousing bolts
Pressure plate bolts
Clutch fork bolt and T-block
Clutch master cyl-firewall bolts
Clutch slave cyl bolts
Clutch fluid reservoir bolts
Torque arm bracket and bolts (bolt pattern is different)
Shifter base bolts
Tranny mount bolts (may be different thread pitch)
There may be others I'm forgetting.
Old Aug 27, 2003 | 07:03 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
The flywheel bolts are different lenght than the flexplate bolts (flexpate=auto flywheel) I made that mistake once.
Old Aug 27, 2003 | 08:00 PM
IrocindatZ's Avatar
Car: 1989 IROC-Z
ok does anyone have the numbers on these bolts as far as what size they are so i can get them from a auto part store.?.
thanks
james
Bubbajones_ya
Aug 31, 2015 12:02 PM
Hello, Michael
Aug 20, 2015 03:19 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
