timing and trans shift relation
Old Aug 27, 2003 | 06:31 PM
mrzud's Avatar
Is there any relation between timing and the trans shifting?
I mean specifically if my cars timing is improporly set at 20 degrees would it effect the transmissions shifting?
Old Aug 28, 2003 | 10:45 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
No. The governor in the transmission decides that usually and the kickdown cable decides downshift. Is your tranny computer controlled?
Old Aug 29, 2003 | 07:37 AM
mrzud's Avatar
im not sure
700r4 is what i have
Old Aug 29, 2003 | 06:41 PM
TA5LiterHO's Avatar
It should not be computer controled then. The 4l60e is. My 700r4 when I had it did the same thing. They make governor recalibration kits to adjust the shift points. They are not hard to install and don't cost too much. I am not sure what suddenly make the 700's start doing this though. Mine did it right after its first rebuild. May need a new TV cable. I have heard that can mess things up pretty good to if that is out of adjustment.
Old Sep 3, 2003 | 06:19 AM
mrzud's Avatar
thanks
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
The_Phoenix
Feb 4, 2016 07:10 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
