TH350 to 4 speed manual
Old Sep 1, 2003 | 05:39 PM
AdamZ28A's Avatar
I have a 82 Z28 that originally had a metric 200, then a th350, then I put in a 700r4, now I am looking to put in a 4 speed manual out of a '81, other than the "torgue tube" mounting ( I will custom make a cross member), will the cluth and trannyand linkages bolt in? I also still have the original driveshaft for the shorter th350/m200. Has anybody pulled this off before? Any input would be very helpful.
Old Sep 1, 2003 | 06:30 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
if its a saginaw, its not worth it
if its a T10, go for it
you can tell the difference by the reverse shift location
i beleive you might need a special bellhousing
Hotrodboba400
Dec 10, 2019 07:07 PM
383cam
Sep 9, 2015 06:01 AM
angel2794
Sep 8, 2015 06:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
