T-56 Install question
Old Sep 2, 2003 | 06:41 PM
IrocindatZ's Avatar
Car: 1989 IROC-Z
Engine: 350 TPI w. Bolt_ons
Axle/Gears: Dana 44 3.73
Ok guys i have a quick probably stupid question. it is can i drive my car with out the torque arm temporarily because i didnt get the other side of the mount that goes to my transmission and i need my d*mn car back.......
Another question is how do i connect the wires my my old trans(700r4) in my 89iroc to the t-56? the inouts in the t-56 are different and i have no idea how to get the nessasary wires into the trans.....
A LITTLE HELP PLEASE GUYS.......
thanks
James
Old Sep 2, 2003 | 07:07 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
James,
I wouldnt drive the car without the torque arm. You could easily twist or break something. as far as the wiring questions
Vehicle speed sensor (leave about five inches of loose wire on the end of the sensor plug-in so you can splice your spedometer wire into the speed senor wire). Try to grab the sensor plug-in off of the donor car otherwise the dealer is the best place to locate one. They tend to run about $52 for the actual sensor and $19 for the plug-in.
that was taken from our board...
http://pub107.ezboard.com/fsicracing...picID=33.topic
go there for a complete how-to on the swap..
Old Sep 2, 2003 | 08:34 PM
IrocindatZ's Avatar
Car: 1989 IROC-Z
ok whats the password
Old Sep 6, 2003 | 03:27 PM
rguevara's Avatar
Check your transmission mount to make sure it is properly secured and has plenty of rubber. This happens to my 89 occassionally and torquing it down solves the delimna. It's also low cost...
Old Sep 7, 2003 | 07:14 AM
Car: 1990 Iroc-Z
http://web.ics.purdue.edu/~trull/tranny/
just try that one..
Old Sep 8, 2003 | 11:23 AM
IrocindatZ's Avatar
Car: 1989 IROC-Z
ok thanks guys im all done with it now ....love the t-56
james
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
cRoe4
Aug 7, 2015 08:46 PM
