aluminum driveshaft
Old Sep 12, 2003 | 05:11 PM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
aluminum driveshaft
ok, I got a 305 right now and its got some pretty decent mods on it, such as headers exhaust gears and it runs good. i plan on dropping in a 350 at some point. maybe even super charging it later.
well my question is.....i know there is a point where you need a heavy duty drive shaft because the aluminum wont cut it. would a 350 tpi with bolt on mods be alright for an aluminum drive shaft or will i need a stronger one? and what about if i added a super charger?
i got the stock drive shaft right now and I want it to go.
thanks
Old Sep 12, 2003 | 06:19 PM
Dwayne88IROC's Avatar
Car: Cars
Engine: SB
Transmission: manual
Axle/Gears: 9bolt
I have my stock Al drive shaft behind my 383. All I did was go to solid u joints. I'll let you know if it breaks.
Old Sep 14, 2003 | 11:19 AM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
ok, but assuming that its strong enough, how much weight am i going to save by going aluminum?
Old Sep 14, 2003 | 01:41 PM
Car: Cars
Engine: SB
Axle/Gears: 9bolt
I've never compared the weights between the 2. I don't think it's much more then 10#'s.
Old Sep 14, 2003 | 03:29 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
The stock 2.5 steel is 17 pounds and the 1LE 2.75 aluminum is 12 pounds.
Old Sep 15, 2003 | 01:19 AM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
dosnt seem like much of a gain. any other advantages to aluminum? i hear it dosnt vibrate like the steal one at high speeds.
Old Sep 15, 2003 | 01:45 AM
Kandied91z's Avatar
your taking rotational mass off of the drivetrain which is a huge gain overall..
should be go to 400-450 rear wheel area. after that i'd want steel. if you get one for a deal go for it, otherwise there are alot of other things to do with $100.
Old Sep 15, 2003 | 03:23 AM
Dr G's Avatar
Theres a thread over on the power adder forum that I think may interest you:-
https://www.thirdgen.org/techbb2/sho...hreadid=197986
Any power adder people using an aluminum driveshaft?
Old Sep 15, 2003 | 11:33 AM
Drone's Avatar
Car: 97
Engine: 3800 v6
Transmission: AUTO
well im looking to make like 350-400 hp for a daily driven car. so im guessing aluminum is my best bet....unless anybody else wants to suggest otherwise. thanks guys.
Old Sep 15, 2003 | 11:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
TPI will protect your drive shaft from ever seeing too much stress, seeing as how that DS works fine in the LS1 cars. I don't think you'll have too much to worry about.
Linson
Oct 24, 2025 02:00 PM
loud91rs
Oct 5, 2015 10:05 PM
