Mettalic flakes in pan on fresh TH350
Old Sep 16, 2003 | 09:21 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I recently got my car back with a freshly built TH350 and 3500 stall convertor. I trailered the car home and took it for a short 1 mile drive. The first to second shift was delayed as I mentioned in an earlier post. I trailered the car back to the shop and they found metallic flakes in the pan and filter. They said the trans looked fine and they suspected the convertor. They sent the convertor over to the shop I got it from and they cut it apart and said it looked fine. Any ideas where these flakes might have come from?
Old Sep 17, 2003 | 01:42 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Mettalic flakes in pan on fresh TH350
Did you have a tranny fail before? If so some of the junk may have been stuck in the trans cooler if you run one. Just a thought.
Old Sep 17, 2003 | 08:15 AM
Blackroc86's Avatar
Car: 1986 Iroc
The trans that came out was clean, nothing in the pan. All the cooler lines and cooler were flushed anyway.
Old Sep 17, 2003 | 12:46 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
Doesn't sound good then Let us know what they find.
Old Sep 17, 2003 | 01:37 PM
Pro Built Automatics's Avatar
Were the flakes brass in color? If they were, that is a thrust washer most likely, not good.
Old Sep 17, 2003 | 01:48 PM
Blackroc86's Avatar
Car: 1986 Iroc
The builder said they were grey maybe aluminum. I am going with a different TC as the builder has torn the trans down completely and could find no problem with it.
Old Sep 19, 2003 | 04:55 PM
BA_TA_420's Avatar
it could just be from the machine work and stuff. i know thats why you have to change the oil in a new engine the first 500 miles casue of metal flakes from machining
Old Sep 19, 2003 | 07:44 PM
Blackroc86's Avatar
Car: 1986 Iroc
The 1-2 shift was delayed by 2 seconds so that is why the car was returned to the shop. They found the metallic stuff in the pan and filter. Since then they tore the trans down and checked everything out. The convertor was returned and they cut it apart and could find no problem. The trans is back in the car now with a different convertor and is working well so far.
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
