is t5 swap worth doing
Old Sep 16, 2003 | 11:02 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
my 700r4 is junk, would swapping a t5 from hawks worth 750 be better? i like driving the stick which i have in my truck so figured it may be fun in the z also.
Thanks Jeff
Old Sep 16, 2003 | 11:46 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i personnaly like standard trannys for street cars. if u prefer a standard go for it. there is an upgrade kit out now for the T5 to make it hella strong plus theyre extremely easy to maintain and swap in.
rjmcgee's Avatar
I did the swap this spring and it is the single best modification I have done. I don't know how much it improved performance because I also went from 993 smog heads to Pro Lightnings and from an RV cam to a Comp XE274 all at the same time. Sure makes the car more fun to drive plus I think it really changed how the car handles now. Doesn't always feel like the front end is plowing.
Old Sep 16, 2003 | 11:50 PM
supermaxxbasher's Avatar
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
see and then if you put in a bigger cam you won't have to worry about a stupid torque convertor. Thats what I like about it.
Old Sep 16, 2003 | 11:54 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
I hope its worth it im doing it next week.
Old Sep 17, 2003 | 05:43 AM
bubbareno's Avatar
Car: black on red 92 rs
Transmission: t-5
If you do it? Use a centerforce clutch. I may onley have a lo3 but there great.
Street Lethal
Apr 30, 2019 12:14 PM
draco
Oct 4, 2015 09:25 PM
bellez77
Sep 5, 2015 08:39 PM
lt1z350
Aug 28, 2015 05:57 AM
hokis
Aug 9, 2015 03:57 PM
