Swapping rear ends
Old Sep 19, 2003 | 08:40 AM
dhjr's Avatar
Swapping rear ends
Going to go pick up an IROC disk break rear for my RS this weekend. But before I do the install have a few questions. First one, should I replace my master cylinder with one for an IROC? Is there any difference in master cylinders for a drum brake rear and disk brake rear? Or would it be ok to just install a Wilwood (or similar) adjustable proportioning valve?
Thanks in advance for the help.
David
Old Sep 19, 2003 | 10:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It depends on the disk brakes that you get.
If they're the aluminum PBR calipers, then their hydraulic requirements are similar to those of drums, and the MC and PV will work. In fact those parts are the same in 90-up cars with those brakes.
If they're the crappy cast-iron Saginaw calipers, then their hydraulic requirements are quite different from drums, and the MC and PV will probably need to be changed. Additionally, the calipers will probably need the recall kit installed, and doing the PV mod would probably be beneficial.
Since you say "IROC rear", and the vast majority of those were Saginaw-equipped, odds are you'll need to do some other work besides just the rear swap.
Old Sep 23, 2003 | 12:31 AM
dhjr's Avatar
What other kind of work do you mean? According to the guy I am buying it from, the rear has 3.73 gears in it already and the posi unit was reworked. Going to paint the rear with POR 15 and put a different cover on it. Along with new pads and maybe rotors. Do you know where I can find slotted or cross drilled rotors for this rear?
Thanks for the help.
Old Sep 23, 2003 | 05:51 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The paragraph right before the one you quoted.... since nearly all IROCs were produced before the changeover to PBRs, nearly all "IROC rears" have Saginaw calipers; so you'll need to change the MC and PV, and install the caliper recall kit, and probably do the PV mod, if you want them to work reasonably well (as well as they can that is).
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
