trans mount
Old Sep 20, 2003 | 05:39 PM
mikes92rs305's Avatar
trans mount
i know i know...search but i did. i cant get mine out for the life of me. i used some WD-40, some PB Blaster...still no luck. i think they put it on with an air gun and i dont have one! WAHHHH! anyone have any tips? i cant get the x-member out nor the trans mount.
Old Sep 20, 2003 | 10:29 PM
onebinky's Avatar
Even if they used an impact to put it on, you should be able to get it off pretty easily. Try using a 1/2 ratchet with a 6 point socket. If that still isn't enough force, put a piece of pipe or square tubing on the end of the wrench and use it as a breaker bar. Once you crack it loose, continue to tighten and loosen the bolts as you go. If you don't, it might build up to much resistance with the rust and snap your bolt or ruin the threads in the frame. Also, once you get it loose and have threads exposed, spray some PB Blaster on it again.
Good luck,
Matt
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
jharrison5
Aug 19, 2015 05:53 PM
timonator
Aug 11, 2015 09:56 PM
