turbo 200c out 700r4 in
Car: 1982 t top,,z/28,
Engine: 409ci vortec
Transmission: all steel t700r4,1300 stall yahooooooooooo
will my mechanical speedo drive from the 200c bolt into the place where the electronic speedo drive is on a t700 r2 ,,
my car is a 1982 cable speedo
my new gearbox will be a lock up,model t700r4 from 1988
with electronic speedo
Car: 1989 C4
Axle/Gears: 307
You will need a non electronic speedometer housing (sleve) and the correct gearset for your differetial ratio and tire diameter. This is the time to make sure everything is correct. www.700r4.com/ has the calculator so you can double check. The crossmember will not directly bolt a 700r4 up either, Spohn makes one that will bolt right up. The tq arm has to be either replaced or shortened a few inches to work. Ive been down this road, it's a swap well worth the effort even more worth it if you were replacing it with a T5 but.....
how do i tell what model t700 i bought,, aparently the 83 to 85 models are junk,,,,the1987,s up to the electronic models are better,, and stronger
Dragonsys
Sep 25, 2015 03:51 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
