T-5 conversion, please help
Old Sep 21, 2003 | 01:10 PM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
I'm doing a T-5 conversion on my automatic 82' camaro and I can't figure out how to put the hydrolic clutch assembly in. could someone take a pic of theirs so i can try to figure out what im doing wrong? thanks
Old Sep 23, 2003 | 10:03 AM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Drill a hole
I don't have a pic, since I sold my car. But when I did that conversion, I had to drill a couple holes.
If you look at the firewall in the are that you think the clutch master should go, you'll see a a little round pad where the MC pkes through, and the pad extends on either side, for the bolts. Basically the mounting flance for the MC is stamped into the firewall, but the holes arean't punched at the factory.
You need to get a hole saw and drill the hole cor the MC, and then using drill bits, drill the holes for the mounting bolts. It's not too hard. Good luck!
Old Sep 23, 2003 | 10:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
My car is a 83, and I also did the conversion...
Mine started out with a manual trans. I enlarged the existing clutch linkage hole a little bit and drilled the 2 holes for the U-bolt. AFAIK your car should have the knockout on the firewall for the manual linkage rubber boot. Use that, enlarge it slightly in the downward direction, and use the gasket that comes with your new clutch master cyl as the template for drilling the other 2 holes.
Old Sep 23, 2003 | 09:31 PM
Engine: electric
Axle/Gears: 10 bolt
thanks, i'll give it a try
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
