'Cnack sounds' from under car
Old Oct 1, 2003 | 12:37 PM
Flameredroc's Avatar
Car: 88 TA
Engine: 350ci
Transmission: Always broken 700r4
Well first I'm sorry for the clumsy way in which I express myself, as I don't have a dictionary of automotive terms
This is kind of a strange problem. Whenever I turn or move the steering weel, there's a cnacking sound from under the car, seemingly coming from the steering links or somewhere... I'm missing the correct terms!
Someone from a special Pontiac forum said, there were 8 places where one has to apply grease, and the cnack sound would disappear.
So, does anything of the steering stuff need grease somewhere?
Thanks for any help
Flameredroc
Old Oct 2, 2003 | 05:07 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I would check to make sure all of your steering linkage is snug (not about to break).. Then grease them...
Old Oct 6, 2003 | 08:22 AM
Car: 88 TA
Engine: 350ci
okay so it has to be greased?? where??
and how can i check its not about to break?
please guys give me some advice, i'm having a 700 miles travel ahead of me and i dont wanna go with the car making those sounds.. thanks!!!
Old Oct 6, 2003 | 09:34 PM
thirdgen88's Avatar
Car: 1995 Corvette
Under your car, you will see the linkage for the steering. There will be 4 grease zerks on the tie rods (2 inner, 2 outer), and 1 grease zerk on the idler arm (on the passenger side). To check to see if they are bad, you can grab them and see if there is any play there, or have someone turn the wheel and see if you can hear/feel any play below.
BTW, there are also grease zerks for the lower ball joints on the lower control arms.
This should probably be moved to suspension/brakes...
Old Oct 7, 2003 | 02:02 AM
Car: 88 TA
Engine: 350ci
... or just be left here in peace, coz that will hopefully solve my problem i'll have a look at it this weekend, thanks for the hints!
Frozer!!!
Jan 19, 2024 04:55 PM
midias
Aug 22, 2015 01:42 AM
MY87LT
Aug 17, 2015 08:43 AM
mustangman65_79
Aug 8, 2015 12:07 PM
gwade12
Aug 8, 2015 08:17 AM
