What Rear End is in the bird
Old Oct 1, 2003 | 07:02 PM
LedZep's Avatar
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
Ok I found a 84 Firebird with VIN Number 1G2AS87L5EL217825 Now how do I know that this is not a TransAm (body is to gone to tell) does the VIN decoder tell if its a TransAm, SE, or what? Also I know that 84 has a lowest gear ratio of 3.08 which means no matter what this must be better than my 89 Formula with a 2.73 open? Thanks for any advice. Also how do I distinguish between posi and open on the tech boards? https://www.thirdgen.org/newdesign/tech/techdb.shtml
Thanks for any help
Old Oct 1, 2003 | 10:14 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I threw the Vin in the Decorder and heres the info:
Made in: United States
Manufacturer: General Motors
Make: Pontiac
Restraint System: Manual belts
Carline Series: Firebird
Body Type: 2 door coupe
5 is the CHECK DIGIT.
Model Year: 1984
Assembly Plant: Van Nuys
Production Sequence: 217825
If you could get your hands on the RPOs it would make your life a lot easier, course probably not to easy if body is gone.
Does the Carline Series tell if it's a Firebird/Formula/Trans Am? I don't know. I guess I could get my VIN off my formula and plug it in and see but I'm working atm.
Old Oct 1, 2003 | 10:30 PM
Knyghtmare's Avatar
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Where do you find this decoder?
Old Oct 1, 2003 | 10:32 PM
Engine: 383 SBC
it's on the thirdgen.org home page...
Vin Decoder
RPO Decoder
Old Oct 2, 2003 | 05:54 AM
LedZep's Avatar
Yes, I know how to decode the VIN, but it really doesn't tell you anything about the rear end. Or if the car was a SE or a TransAm would the VIN Decoder tell you that? Any opinion on an 84 rear end? Also my car only has 81k miles on it..
Also where is the RPO Code located?
Thanks for any help.
Old Oct 2, 2003 | 08:51 AM
Engine: 383 SBC
My RPOs are inside the center console on the side of it.
Old Oct 2, 2003 | 10:40 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
There is a stamping on the rear axle that will tell you the info on the assembly (ratio, posi/non-posi).. I think it is on the drivers side axle tube toward the front of the car (it has been a while)... I don't remember where I got the chart of all of the numbers though, maybe someone else knows??
Old Oct 8, 2003 | 07:22 AM
brobert's Avatar
i have a picture of the chart
Old Oct 8, 2003 | 09:38 AM
LedZep's Avatar
thank you so much that will help me out alot. But arent I right, any rear end in the 84 Bird has to be better than my 89 Formula's 2.73 open right?
Old Oct 8, 2003 | 06:06 PM
brobert's Avatar
It all depends, in 85 they switched to borg warner. supposed to be stronger. Plus over the years someone coulda changed the 84 internally. You never know untill you check.
Old Oct 10, 2003 | 03:42 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Was the car a 6 or an 8? with a 6 it will have steep gears (typically 3.42) and an open carrier. If it is an 8 the gears will be tiny and it might or might not be posi, To tell if it is posi you need to pop the cover and look into the differential's inspection hold and look for springs. Springs + POSI no springs = open.
I believe that firebird means a base model IE not a T/A or SE.
Old Oct 10, 2003 | 06:27 AM
brobert's Avatar
AS i said b4 read above
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
