Just bought a car, differential died 8 hrs later
Old Oct 5, 2003 | 05:34 PM
thechristopherh's Avatar
I bought a 1984 Camaro Z28 H.O yesterday (and i thought it ran great) Soo this is what happened. I was at a light, tried to put my car into first then i heard a loud popping sound. Now no matter what gear the car is in, it wont move (acts like its in nuetral) I put the car in 1st, looked underneath the car and the driveshaft is spinning. My girlfriends dad said my differential is blown. How much does this cost to fix/replace, and how much more to put in LSD. I have a 1984 Z28 H.O. I also have a (non functional) 1995 Camaro V6. (anyone want any 4th gen parts?) Can i swap the differentials, or would that not work?
Old Oct 5, 2003 | 06:15 PM
ede's Avatar
ede
cheapest and easiest thing to do is swap rears if you broke the one you have. should be able to find one from 100 to 200 pretty easy
Old Oct 5, 2003 | 07:56 PM
Mikes 327 Z's Avatar
Yep, check around, you can find them in junk yards easy. If you want, look for like a 9 bolt rear end and that would last you for quite a while. You can swap a 4th gen rear end into a 3rd gen, but then the wheel offsets are different and I believe the speedo stuff is different too.
Old Oct 5, 2003 | 08:49 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
You could just swap the whole rear with the 95. Probably has higher gear ratio to boot! The only thing will be that your rear tires will stick out 2" more. You could just put the 95 rear wheels on it, or all 4 and get spacers for the front.
Old Oct 5, 2003 | 10:16 PM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Either go boneyard hunting for a diffrential or read the tech article and swap the 4th gen rear in.
You could rebuild the diffrential you have but that will cost $.
Old Oct 5, 2003 | 10:27 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Get a 9 bolt if u can find one
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
86IROC112
Aug 17, 2015 02:00 PM
mustangman65_79
Aug 8, 2015 01:18 AM
