need help with taking TH350 apart, dana...you around?
Old Oct 14, 2003 | 10:39 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I am in the process of taking my friends TH350 apart and putting in a vega sunshell gear and shimming up the intermedite/reverse clutchs per Dana@Probuilt. Does anyone have a good exploded pic of a TH350. I finished putting the Transgo kit in it w/ no problem but this is the first time I have ever been inside the trans. I have pulled the front pump off, there are steels/clutches that sit on a big shaft in the middle. I took the clutchs/steels out, and took the snap ring off the part in the middle. now there is a big drum facing towards the rear of the trans and the input shaft runs the the middle of it. there is a band around the drum that seems to be keeping the drum in the trans. What is the next step to taking it apart and where in the heck is the intermediate/reverse clutch? Dana told me he really couldn't explain what it looked like. If i had a picture I could atleast tell when I am taking each part out where it is.
Once again, Dana @ Probuilt is awesome :hail:
Hotrodboba400
Dec 10, 2019 07:07 PM
Fronzizzle
Feb 9, 2017 09:31 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Fox118
Sep 12, 2015 09:29 PM
383cam
Sep 9, 2015 06:01 AM
