Type "F" in a 700r4
Old Oct 21, 2003 | 08:05 PM
bigswede's Avatar
Car: 1983 Z28
Engine: stock LG4 305
Type "F" in a 700r4
Anyone tried this? It`s an old trick,thinner fluid=quicker shifts.
Old Oct 21, 2003 | 08:29 PM
Pro Built Automatics's Avatar
Type "F" was last used when there was asbestos in clutches (1977). It has less holding power in dynamic situations (where shifts occur) in all transmissions since. The reason it appears to make the transmission shift firmer is that it allows the clutches/band to slide longer at the beginning of the shift, and come on all at once at the end of the shift. A good Dexron III is all you need in most cases. Borg Warner & Raybestos agree with this.
Old Oct 21, 2003 | 09:42 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
what about TrickShift?
Old Oct 21, 2003 | 11:06 PM
breathment's Avatar
type f in a differen't bottle
Old Oct 22, 2003 | 12:07 AM
Cuno's Avatar
B&M recommends Trick Shift or Type F fluid in use in your tranny that has a B&M torque converter
Old Oct 22, 2003 | 12:14 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
trick shift is just type f with some blue dye added for color.
As stated already, do not use it in a modern automatic transmission. Just do a search on it and you'll see people who have had problems because of it.
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
bjpotter
Oct 4, 2015 07:48 PM
92projectcamaro
Sep 29, 2015 07:07 PM
6998poncho
Sep 25, 2015 02:56 PM
