What Gears???
Old Oct 25, 2003 | 03:13 AM
SweetRide45's Avatar
What Gears???
I'm planning in the future to get the TPI Crate Engine from sdpc.
http://www.sdpc2000.com/cart.asp?act...art&catid=1577
Well, w/ that engine, and a pro-built Street/Strip 700R4 w/ the Vigilante Torque Converter, what Rear End would be best?
I currently have a '90 V6 mpfi (that I am changin to TPI w/ that other engine)...I believe it has a 10 bolt w/ 3.23 gears. I can get a Posi 9 Bolt w/ 2.77 gears. Would those gears be good enough to get good output from that engine/trans combo?
Let me know what you think.
Thanks!!
Old Oct 26, 2003 | 06:48 PM
I'll answer my own question..."NO"...lol
Ok, I found a different Differential. It's a Borg Warner 9 Bolt, Posi, Disc Brakes, w/ 3.23 Gears. At least it's a 3 Series. AND, since I already have those gears, speedo will be correct. He's got it for $250. I think it's a pretty good deal. I think I'll run that route.
Final outcome, 3 Series, Borg Warner, 9 Bolt, Stronger Rearend w/ Disc. I don't think I could go wrong
Old Oct 26, 2003 | 07:12 PM
vjo90RS8's Avatar
Car: 2002 Z28
no need to worry about what series the differential is on a 9 bolt, they are all the same. Also, with a 9 bolt if you want to upgrade gears in the future they are a **** load of money.
Old Oct 26, 2003 | 07:21 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
there are in fact different series carriers for the BW 9 bolt.
for example, i have a 2.77 bw rear and i would not be able to put 3.73s on it unless i upgrade from the the 2 series carrier to the 3 series carrier.
just FYI.
Old Oct 27, 2003 | 09:16 AM
Would it make any sense to go from the 3.23's to let's say, 3.42's?? I don't want to go as high as 3.73's as for economy (cruising wise), and just overall the high revs when going "slow"...lol...
Thanks for the input.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
