Should my 700 shift this hard?
Old Oct 28, 2003 | 07:57 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I just put in a Corvette servo from Pro-Built and I already have a shift kit in. I replaced the control arms with lakewoods and the torque arm bushing with urethane from energy suspension. It seems like every time it shifts it jerks real hard and throws me forward, I am not used to being in a car that shifts THAT hard is this normal???
Old Oct 29, 2003 | 06:50 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
hmmm... I would try resetting your TV cable and see where it goes from there. Sounds like it may need a little adjusting. Hope that helps.
Old Oct 29, 2003 | 08:14 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
umm. thats what shift kits do.
they take out the slipping that makes it slide into each gear, and they make it jam into each gear harder and faster.
Old Oct 29, 2003 | 12:38 PM
GASGZLR's Avatar
Already set the TV cable, it is fine at WOT. I opened the throttle all the way and it clicked into place, I'm not sure about part throttle though since I have a carb instead of a throttle body.
How far should the cable pull out from idle to WOT or vise versa??
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Breazlan
Sep 25, 2015 11:20 AM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Third_Gens_Rule
Sep 3, 2015 06:55 PM
tonys91rs
Sep 2, 2015 07:07 PM
