What's normal for reverse in T-5's??
Old Oct 28, 2003 | 10:18 PM
onebluemcm's Avatar
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
Since I got my IROC a few months ago it has mostly been in storage. The few times I've driven it it has been perfect. One thing I'm noticing form time to time is that when it is sitting still and running with the trans in neutral and the clutch pedal out (just sittin' there running) when you kick the clutch in and try to go into reverse it sometimes resists or make a slight grinding noise as it engages reverse, kind of like reverse is not fully synchronized. Is this normal or am I looking at a shot synchro??
Hmmmmm....... Reverse works just fine once it is in gear, and if you kick the clutch in and wait 30 seconds it will go right in with no grinding at all. What do you all think?
Thanks, K
Old Oct 28, 2003 | 10:27 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I have seen a lot of t-5's do that with miles on them. new they don't. I always went from 5th to rev.
Old Oct 29, 2003 | 12:21 AM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
I dont believe reverse is a syncroed gear, my trans does the same thing. If I shift into 5th then reverse, it stops everytyhing moving in the trans and it wont grind.
Old Oct 29, 2003 | 05:55 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Yup 91dubz28, is right on, no syncro for reverse, 5 to R is the trick!
Old Oct 29, 2003 | 12:27 PM
onebluemcm's Avatar
Car: '89 IROC-Z
This place is the shiznit - you all are great with replies.
I'm learning so much about my new-to-me IROC-Z by asking questions like this on here - i did not know, but was beginning to think, that reverse was not a shnchro'd gear and you all quickly confirmed it - awesome.
Thanks for the answer guys,
K
Old Oct 29, 2003 | 12:48 PM
Teenfixing88RS's Avatar
Car: 1988 Camaro RS
He's right!! I had that problems a few weeks back... Just got to fifth then bring it down to reverse.. ta da!!! no more grinding:lala:
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
luvofjah
Sep 26, 2015 08:28 PM
DARKmj16
Sep 9, 2015 04:07 PM
