what happened to my bird ??
Old Nov 3, 2003 | 07:17 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
i was on my way home tonight and i had my hand on the shifter and it slipped into neutral and kept going for some reason into reverse, but i dindt have hte button pushed in. then when i went to park it i had to back up to get in my spot and it won't go into reverse now it just sits there. When it is in neutral it puts it into drive and it is all messed up now
anyone got any idea waht happened ??
Old Nov 4, 2003 | 04:05 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
You fukt it up.Time for a new tranny (or a rebuild). Future refrence buttons fail so it is a good idea not to push on the shifter while it is in D.
Old Nov 4, 2003 | 10:18 PM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
possible cable caught on something or slipped. Try pushing in the button and moving it all the way down to "1" and then moving it back up and see where it goes.
Old Nov 5, 2003 | 02:26 PM
Car: 91 formula
Transmission: t5
well it poped back into reverse when i rolled it down my driveway with teh car off, and now it seems to be normal, but hte fluid is cooked, should i have it taken apart and looked at or just change the fluid and hope for hte best?
Old Nov 5, 2003 | 03:04 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Make sure the linkage didn't come loose at the transmission. Its common for the two bolts that hold the bracket to come loose.
Old Nov 5, 2003 | 03:25 PM
Car: 91 formula
Transmission: t5
gm tech, do you think the tranny is fried, or the fluid just got roasted from it being stuck or whatever happened, it seems to shift and go into gear fine now, but ihavn't tried driving it
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RS Reaper
Oct 17, 2018 07:52 PM
racereese
Oct 3, 2015 03:46 PM
