HARD rattle at start
Old Nov 4, 2003 | 09:35 AM
91CamaroDude's Avatar
Car: 91 Camaro RS, BEAST
Engine: 305 TBI
I have a 91 RS 305 tbi with a t5 tranny. Whenever I start moving, redlight or whatever, the car basically tries to rattle apart until the clutch is completly out. Im talking like it feels like the wheels are bouncing off the ground! My clutch was replaced 8k miles ago. its has been doing this for a while but has gotten worse in the past month. whats my problem? thanx
Old Nov 6, 2003 | 12:07 AM
VERTIGO Z28's Avatar
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
ooooh crap
Have someone push in the clutch after you have the car up and the inspection cover off. Use a pliers to try and move the flywheel clockwise and counterclockwise. I think your flywheel bolts are loose. Watch the crank while doing this to determine if there is slop. If so you know what to do. Good Luck and use Locktight.
PS use a torque wrench for the bolts
Just my expierience!
Old Nov 6, 2003 | 11:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Did you have the flywheel resurfaced? Replace the pilot bearing / bushing? Motor mounts good? Any of those things can cause clutch chatter, in addition to just a generally cheap clutch if you went with a low-bid unit.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
mustangman65_79
Aug 8, 2015 12:07 PM
