Quick bellhousing question
Old Nov 4, 2003 | 02:47 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
I have done many searches on this and can not find the answer so here goes. Is there a hydraulic bellhousing that will bolt to a super T-10 tranny and fit under an F-body? I am looking to upgrade to a hydraulic clutch setup from the factory mechanical. Thanks in advance for your knowlege.
Bill
Old Nov 4, 2003 | 04:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No.
Old Nov 4, 2003 | 05:25 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
Lakewood PN 15020. It uses the factory slave cylinder from the '84-'92 model cars.
MCM
Old Nov 4, 2003 | 06:27 PM
groundrat's Avatar
Car: 91Z28
Thanks for the help. Where can I get a Lakewood bellhousing?
Old Nov 4, 2003 | 07:49 PM
Car: '82 Trans Am
Transmission: TH475
Here at Summit Racing.
MCM
Old Dec 1, 2003 | 05:44 PM
69-er's Avatar
I thought Saginaws, Muncies, etc had the same bolt pattern as the T-5 transmissions. I want to do the same thing, mount a four speed Saginaw to the bellhousing from a T-5.
Larry
Old Dec 1, 2003 | 10:43 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
They are, but the mounting holes for a T5 are rotated some 15-17° from straight across. Here's a hydrualic T5 bellhousing...
redmaroz
Aug 16, 2015 11:40 PM
383backinblack
Aug 15, 2015 06:36 PM
happyhapka
Aug 15, 2015 04:42 PM
