Anyone ever installed a torque converter lock-up harness?
Old Nov 7, 2003 | 02:41 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I was looking through jegs..and I saw this: http://www.jegs.com/cgi-bin/ncommerc...74&prmenbr=361
Can anyone please explain to me what this does? Does it keep the torque converter from going in and out of overdrive or what? How does this install??? Any help would be appreciated. Thanks!
Old Nov 7, 2003 | 07:15 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive used the b&m kit for non CCV but this one is a tad different. Apperently this fools the ECM into thinking its at a lower speed. So if your going 35MPH and the TC usually locks it will delay it to a certain speed like 45 MPH. This can help in city driving when stop and go traffic is more then "X" speed or if you like to race from a roll. ID spend money else where if I still had a 700r4,
Old Nov 11, 2003 | 01:36 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I have a 2500 stall, that is a lock up type. I plan on upgrading to a 3000 stall, but I do not want to retain the lock up feature. Lock up helps out on the gas mileage, but gets in the way of performence. It depends on whether or not you do a lot of freeway driving or drag racing. I guess what I'm suggesting is un plug the lock up plug on the side if the transmission, and drive the car and see what you think.
Old Nov 11, 2003 | 02:37 PM
Engine: 5.7
I have a stock torque converter on it now.....I usally drive in the country/city....but when i go a steady speed of about 40-45....it shifts into overdrive....and it seems pretty doggy...thought maybe this lock-up would help out on that....I went ahead and ordered it....should be here thursday...I can't install it till probably next spring though....it's getting cold here...and I doin't have a garage of anything....
Old Nov 11, 2003 | 02:47 PM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
It's real easy to instal ,altough you have to go under the car.
It' just a matter of putting the harnass between the already excisting wire at the tranny.
5 minutes work.
I have it on my car,don't notice a great difference,the lock up will only in 4 and at slightly higher rpm.
Old Nov 11, 2003 | 03:06 PM
Engine: 5.7
5 minutes work.
glad to hear it's not that hard to install....I haven't even looked to where it's supposed to be installed yet. I'll have to put my car on jackstands right?
Old Nov 12, 2003 | 02:12 PM
You need to unplucg a wire on top of the tranny, and plug the harnass in, so yes you need something to lift/ work under the car,but with a good pocket torch and a blanket on the ground to crawl on, you might succeed!
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
gwade12
Aug 8, 2015 08:17 AM
