factory replacement shifter
Old Nov 8, 2003 | 09:26 PM
11sORbust's Avatar
factory repolacement shifter
Is there any auto shifters that will work with the stock firebird console?
Old Nov 10, 2003 | 11:04 PM
Daishi's Avatar
Car: 1988 Camaro IROC
Axle/Gears: 3.27 9 bolt posi (non 1le)
Old Nov 10, 2003 | 11:54 PM
Bandit5's Avatar
The Hurst Dual Gate Shifter II also works... it takes a bit of modification to get it to fit right on the firebirds, but the end result is very nice, plus you get the cool features of the Hurst. Best of all... its not made by B&M!!!
Old Nov 11, 2003 | 09:01 AM
11sORbust's Avatar
That is not a firebird console. I have known about the camaro shifter
Old Nov 11, 2003 | 03:13 PM
Daishi's Avatar
It says right on the box Camaro AND FIREBIRD consol shifter. there is even special bolts and drill hole locations for firebird consol
See? there are options, easy to install too
Old Nov 11, 2003 | 07:37 PM
11sORbust's Avatar
Thank you! My eyes must be retarded . Is there any pics of the setup on a firebird console? I hope that's not just for 82-85????
Old Nov 12, 2003 | 09:26 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
I always see the B&M megashifter advertised for 82-92 CAmaro and Firebirds (EXCEPT 91-92 FORMULA). WTF? I have a 91 Formula and Im putting in a TH350. I guess I have to use the stock or adapt to a HUrst eh?
Old Nov 12, 2003 | 10:09 PM
11sORbust's Avatar
that's what I'm spraying. The 87 console is the same as yours....
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Out-Cast
Dec 31, 2015 04:40 PM
NBrehm
Aug 25, 2015 11:49 PM
