700r4 doesn't shift when cold
Old Nov 9, 2003 | 05:42 PM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
Transmission: 700-R4
we have a car that when it's semi-cold out (0 celsius) that if you shift out of park, and into drive, it won't shift with you
the car won't move, like it's in neutral, and then eventually if you leave it for a while in gear it'll "catch" and then the car will start to shift..
Old Nov 9, 2003 | 11:42 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Check the fluid to make sure its full. When was the last time it was flushed?
Old Nov 10, 2003 | 12:50 AM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
yes it's been filled up..but i don't know when it's been flushed..
also why is it a dark colour instead of bright red? i remember someone saying it's because it's being burned or something?
Old Nov 10, 2003 | 06:17 AM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
burnt tranny fluid is a bad sign. ur tranny is probably fuxored.
Old Nov 10, 2003 | 04:58 PM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
i guess it's slipping a lot now and burns up the fluid..
can i rebuild it myself or is it best to let a shop do it?
Old Nov 12, 2003 | 12:37 AM
onebinky's Avatar
If you're not familiar with it and you don't have the specialty tools, let the shop do it. Most of the time you get a great warranty with it too
jklein337
Sep 19, 2018 06:23 PM
italiano67
Dec 11, 2016 09:21 AM
TreDeClaw
Aug 14, 2015 06:58 PM
drathaar907
Aug 6, 2015 04:20 PM
