is a s-10 t5 (from 4cyl) the same as v8 t5???
Old Nov 10, 2003 | 02:33 PM
stevedave454's Avatar
Car: 91 S10
i am doing a V-8 swap into an S10, although im building a nasty turbo motor for it, with which i will use an auto, im thinking bout throwing a stock 350 in it for the time being, im told that my t5 will work but i must change out the input shaft (its 14 splines or something) and im told any 4sp bellhousing will work. can any one give me some detailed info on the swap as far as parts needed and cost. i know a tranny builder so i can get labor pretty cheap
Old Nov 11, 2003 | 01:13 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
no a 4cly t5 is not the same as a v-8 t5.
Old Nov 11, 2003 | 06:19 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
not even close.
bolt pattern different
s10 t5 clocked at 0, camaro clocked about 7 deg
camaro shifter is futher back then s10
splines different
and a v8 would more then likely rip a 4cyl tranny in half the first time you gave it any hell.
nwardoh
Jul 11, 2004 11:27 AM
Z-Man 85
Jan 13, 2002 12:52 PM
