t5 VSS Change of Speedo Gear ?
Old Nov 14, 2003 | 09:16 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I just picked up a new speedo gear for my t5. It came attached to a metal shaft and is not easily removable.
From the original Vss I was able to pop off the gear on the top, while trying to actually pull the whole shaft out.
I tried to then pull on the shaft , but I did not want to break anything so I have let it alone.
My question is, for those that have changed your t5 VSS driven gear, did the new one look like the one pictured below?
How did you go about swapping the gear?
I was thinking of tapping the gear off the new shaft and placing it on the old....
Old Nov 15, 2003 | 03:31 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Well I tapped the shaft off the gear and it popped right on the VSS.
jklein337
Sep 19, 2018 06:23 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
mizz0313
Aug 12, 2015 06:45 AM
