Stock rear with eaton posi and 3.42's handle 400hp?
Old Nov 14, 2003 | 11:53 PM
25THRSS's Avatar
Just like the question states. No other mods except eaton posi with motive 3.42's. I may weld the axle tubes, but don't know yet. Without any modifications can it take 400 flywheel hp with slicks?
Old Nov 15, 2003 | 01:22 AM
Chickenman35's Avatar
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Re: Stock rear with eaton posi and 3.42's handle 400hp?
Ouch...the Slicks are gonna hurt it. I doubt it will last long Drag Racing
Old Nov 15, 2003 | 07:08 PM
PhilM's Avatar
Car: Accepting applications...
Yeah, I would have said sure right up until the part about slicks...
Old Nov 15, 2003 | 08:20 PM
25THRSS's Avatar
I'm not talking rear wheel hp here, just flywheel hp. Are LS1 guys able to do it? just curious.
Old Nov 15, 2003 | 11:01 PM
Car: 86\92 Mutant
Engine: 355CI 430HP
Yeah...400HP at the flywheel...and slicks...is gonna go Kaboom. Probably sooner than later...IMHO.
Old Nov 16, 2003 | 07:37 AM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
hehe i put 500 flywheel hp to mine....on slicks...it actually lasted a little while....i knew it was doomed though....finally twisted the axle off
but ya 400hp will kill it too
Old Nov 16, 2003 | 10:12 AM
bohn333's Avatar
Car: 1987 Trans am
Install some Moser axles and weld up the axle tubes with a stud girdle and you'll be fine. Aslong as you don't have a transbrake..thats what really kills rearends.
Old Nov 16, 2003 | 11:17 AM
Car: '91 Camaro RS
it'll still break, trust me.....it might last a little bit longer, but in the end 7.5" ring gears are too small as are all the other components in the housing.....you just need something tougher
Old Nov 16, 2003 | 12:18 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I think it will last for awhile with an automatic. If it was a stick car not quite as long.
Old Nov 16, 2003 | 11:04 PM
Car: '91 Camaro RS
maybe....but dont forget the momentary torque multiplication you get with an automatic....that might even the playing field a little
Old Nov 17, 2003 | 12:26 PM
WS6Formula305's Avatar
Car: '88 Firebird Formula
Engine: 360hp/417ft. lb. 350
Transmission: Pro-Built Street/Strip 700R4
My stock 3.23 posi rear end on street tires should live up to my 360fwhp right? I'm gonna have BFG G/Force T/A KDW's in two weeks on there, and the car won't be going to the strip for a very long time (until the transmission gets replaced).
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
IroczFan
Oct 6, 2015 10:13 AM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
