Where do I fill my axle with grease?
Old Nov 16, 2003 | 04:20 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
I have looked everywhere on my axle for a place to put the grease into. The only thing I have found is a little skinny **** that can twist, but does not come off. Is this it? It sounds like I need to grease my axle, but I can't find the place! Please help!
Old Nov 16, 2003 | 04:33 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
If you have a ten-bolt, there is a filler plug on the upper passenger side of the differential housing; use a 3/8 drive ratchet to remove the plug. Fill it untill the fluid just start to run out the hole.
Pete
Old Nov 16, 2003 | 05:16 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Someone better say grease is not what you use. You want to use a proper gear lube. Course it could work but not sure how it would work out. Would most likely take a large coffee can full of grease to fill it.
Matt
Old Nov 16, 2003 | 05:31 PM
onebluemcm's Avatar
From: Ithaca, NY - 10 sq mi surrounded by reality - I'm SOL!
Car: '89 IROC-Z
Engine: 305 TPI in stock trim
Transmission: T-5 w/ Hurst B/P shifter
I second that motion, but I'm saying definetly don't use grease - that's just slang for gear lube (oil or some call it fluid) for the rear end gears.
That plug is gonna be located on the side, just as Petes 84Z28 said, and won't be in the cover at the rear of the differential if it's all stock.
Just wondering, why do you say it "sounds like it needs grease"??
cheesehomer
Dec 31, 2015 08:48 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
usafirebird
Sep 29, 2015 11:58 PM
Numbah-1
Sep 12, 2015 08:57 PM
