TH350 in 82Z
Old Nov 17, 2003 | 02:35 PM
jrm's Avatar
jrm
TH350 in 82Z
I want to swap out my junk stock 200c tranny for a turbo 350. Is it a direct swap, or do I need some extra hardware?
Old Nov 18, 2003 | 04:52 AM
ronterry's Avatar
Car: '94 Corvette
All you'll need is the B&M Kit (Summit Part # BMM-30299) for 79.95... Since the driveshaft is close to the same length for the 200c, it's a striaght swap. The kit will give you a mounting point for the torque arm, and relocate the trannie mount.
Someone else will have to fill you in on the kickdown cable? Mine has a transgo full manual w/no kickdown needed.
What else, oh you'll need to run a rubber line from the modulator to a vacuum source off the intake.
Ron
Old Nov 18, 2003 | 10:28 PM
rjmcgee's Avatar
You will want the 6 inch tailshaft and like said above, everything else is pretty straight forward
Old Nov 18, 2003 | 11:19 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
hmm I think the bone yard down the road has a couple 82 z28s with 200r4s. Maybe I should grab a driveshaft...will save me money when I do to do my th350 swap. Unless I get the TCI with the 9'' tailshaft.
Old Nov 18, 2003 | 11:59 PM
rjmcgee's Avatar
Get the crossmember and torque arm too. I have two of both of those if anybody is needing one.
Old Nov 19, 2003 | 01:37 AM
ronterry's Avatar
Car: '94 Corvette
Just for the record, there was never a TH200R4 put into 3rd Gens. Stock at least ...The (4) at the end mean 4 speed, and the 200C was only a 3 speed. Two completely different transmissions....
If you check the part on Summit Racing, even the add is wrong which states 2004R (<- that's not even correct), but then again it also states it as a 200C
Here, I had to clip it...
"This bracket kit from B&M allows you to swap a TH350 into your TH2004R or TH700R4 equipped Camaro or Firebird. The kit contains a trans mount, torque arm mount, and hardware. A stock 1982 TH200 driveshaft or equivalent and other GM parts are required."
I think I'll email them to tomorrow, and get that fixed
Ron
Old Nov 19, 2003 | 10:14 AM
Transmission: 4l60e
I thought 200r4s came in 82 models. I know they were 3 speed.
Old Nov 19, 2003 | 04:03 PM
ronterry's Avatar
Car: '94 Corvette
Yeap, only crappy 200C on 82's. Hell they even used them on some of the latter years of the heavy 2nd gens...These are heavy cars, but the HP & Torque were pretty low, so GM saved money.
It never made since, that my '81 had a 200C, but the rear was a bullet proof 8.5"?????????? Needless to say, I swaped in a TH-350 on my '81 years ago...
http://www.nastyz28.com/transid.html
If I had a TH-200R4 I wouldn't replace it with a TH-350, I would just build it up!
I see 200R4 in 'CHP' all the time, so they must be pretty strong???
Ron
Old Nov 19, 2003 | 04:12 PM
ronterry's Avatar
Car: '94 Corvette
Almost forgot, the pan on the 200C looks like the 350 but only has 11 bolts.
Ron
Old Nov 19, 2003 | 06:50 PM
rjmcgee's Avatar
Ron
Another easy way to identify one is by the tail housing. TH350 has a bolt on and TH200 is all one piece.
Old Nov 21, 2003 | 07:01 PM
SLOWFIVEOH's Avatar
Car: 82' Z28 IROC Clone (SOLD)
Engine: 355
Transmission: Built TH-350
Axle/Gears: 3.73 Moser 12 bolt
The swap was pretty simple. Pretty easy, I never hooked up the kickdown. I just pull it back into 2nd if I ever need to. I like it better without the kickdown, But with the 3.73s I hardly ever need it, Unless I am trying to pull on someone. I am wanting to swap out mine for a more highway friendly trans for me to go back and forth to College next year!
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
romcjr
Sep 17, 2015 05:18 PM
LittleFranks
Sep 17, 2015 12:22 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
