Quarter stick
Old Nov 21, 2003 | 03:05 AM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
Quarter stick
I know Hurst made a quarter stick console model but discontinued it. Does anyone have any pics of one installed in a thirdgen camaro? Or advise? Anything? I'm getting a little tired of my mega shifter.
Thanks guys
Old Nov 21, 2003 | 05:22 AM
ede's Avatar
ede
i have a 1/4 stick with a th350 but my interior is stripped. it is a great shifter, best one far as i can tell for a automatic trans
Old Nov 21, 2003 | 10:33 AM
8.2L Trans Am's Avatar
I have a B&M 1/4 stick in mine with a stock center counsole. You just have to make custome brackets, and it sits a bit higher than stock. So you have to give up you ash tray for the shifter cable.
Old Nov 21, 2003 | 11:58 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i had put a B&M prostick in my 82 camaro... its almost the same shifter.
you need to go get some spacers to get it the correct height.... i first got a bunch of washers, stacked them up until i liked where the shifter sat, then i get spacers that size..
once its mounted solidly where i wanted it, i had to remove the ashtray, and radio, and i made a hole in the floorboard JUST under the face of the radio... thats the only way the cable is going to fit.
i plugged the old hole and used a new grommet for the cable...
for the console top, i got some black textured sheet plastic, i cut the stock ashtray part off the stock one and bolted it on... i then cut the sheet plastic to fit the remaning place........ then i just had to cut a hole for the shifter to move thru......
for the reverse lockout, i had to fab up a little extention handle... otherwise it was inside the center console and i couldnt reach it..
a lil more envolved, but well worth it for both the look and feel.
Old Nov 22, 2003 | 02:09 AM
Engine: 350 L98
Thanks for the feedback guys. Really apretiate it. So I'd have to drill a new shifter cable location eh! Is that because the shifter sits so high? When you say you have to remove the ashtray and radio. Do you mean just for the intall? Or are they gone for good?
Any pics?
Thanks:hail:
Chris
PurelyPMD
May 5, 2016 04:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
LC2 TECH
Oct 13, 2015 11:53 PM
Drone358
Sep 28, 2015 04:55 PM
ndndndnd
Sep 28, 2015 08:00 AM
