burnt fluid
Old Nov 25, 2003 | 09:10 PM
white91formula's Avatar
Car: 91 formula
Transmission: t5
burnt fluid
how long can i drive on burnt fluid ? will it have any effect on my tranny and hurt it anymore than it already is or what ?
i just want to know if i will be able to drive it to my garage for the winter, so i do not have to deal with it untill spring time.
thanks
keith
Old Nov 26, 2003 | 12:34 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I think the biggest mistake you could make is change the fluid. ATF has detergents in it that do more harm than good in this situation. I have had a few tranny shops tell me that in this situation DO NOT CHANGE the fluid, as it will make it worse. I can say this from expierence. I would say if you limped it around, it would be fine to drive all winter. But burnt fluid means the clutch material is severly worn, and the steel bands that the clutches ride on are heat checked. Basiclly you will be looking at an overhaul. Been there done that( about 6or7 times). While driving it on burnt fluid isnt exactly good on a tranny, the damage is already done. Just my .02 cents, like I said I've had to rebuilt it several times.
Old Nov 26, 2003 | 02:01 PM
Car: 91 formula
Transmission: t5
the tranny itself is fine, it had a episode, where it got stuck inbetween 2 gears or something, but now it is back to normal, it does it every once and a while, had it checked out and they couldnt find aynthing wrong with it, but this time i tried moving it when it was stuck and it burnt the fluid, so i think the tranny is fine, but the fluid got wrecked because of what happened
i dont know if that makes any sense or not
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Bigold4x4
Sep 28, 2015 05:21 PM
mfp189
Sep 27, 2015 09:25 AM
