clutch master cylinder dead?
Old Dec 12, 2003 | 02:47 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
My TO bearing went bad so I had to replace it, while the tranny was off the vehicle, i was stupid and playing with the clutch pedal. it was extremely stiff, so i gave it some pressure and it gave in then it felt real lose after that. after i got everything back together, the clutch pedal felt the same still. I replaced the clutch slave cylinder and i think i bled the system correctly, but still the clutch pedal is dead. theirs no resistance , when i start the car and i push the pedal in, i still cant shift into any gears.
what can i do to test the master cylinder to see if it is working or not. also, when i have someone push in the clutch, their is no movement from the brandnew slave cylinder. so i know its not that.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
codeysabatini
Nov 10, 2015 04:07 PM
camaro1185
Oct 26, 2015 06:51 AM
Night rider327
Sep 2, 2015 04:18 AM
