Transmission
Old Dec 11, 2003 | 01:53 PM
dongalonga's Avatar
Car: 1990 Chevy Camaro Iroc-Z
Transmission
Ok i think the tranny is on its way out. The car has noticeable lag hen you get on the gas but the rpms are going up. it seems like the tranny is slipping. It also take forever for it to shift into gears. Does it sound like the tranny needs a rebuild. The guy who originally owned the car put in a GM rebuilt 305 less than 2 years ago but didn't rebuild the tranny, and the car has like 150K miles so it is due I would imagine.
Old Dec 11, 2003 | 02:31 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
hey, i see your from lowell.....im from dracut, small world
anyways if you mash the pedal and the car revs up but doesnt accelerate, then the trans is slipping for one reason or another.
first off check the fluid, and make sure its full, and that its not burnt up (if it is, it will look sh*tty and smell burnt)
there are alot of good tranny shops around here like lowell automatic, although they are expensive....sayball transmission on aiken street is good from what i hear too.
i have a few tranny's around, but i dont think i have any 700r4's
Old Dec 11, 2003 | 02:34 PM
Car: '91 Camaro RS
oh for christsake.....its you shawn...you gotta be kidding me
Old Dec 11, 2003 | 02:49 PM
dongalonga's Avatar
hey whats going on man i knew it was you as soon as i saw the 383. yeah i bought marks car for 1500 and all it needed was a coolant temp sensor and appearantly a tranny rebuild. so how is the car?
Old Dec 11, 2003 | 02:55 PM
Car: '91 Camaro RS
its good....off the road for the winter now though, awaiting a fuel cell and new pump.....and possibly and even more aggressive cam
Old Dec 11, 2003 | 02:58 PM
dongalonga's Avatar
Jesus and even more aggressive cam. You are completely nuts Hey if I do need to rebuild the tranny do you think I should go with one of the complete overhaul kits from summit like the Hughes Performance or the B&M Transkit?
Old Dec 11, 2003 | 03:56 PM
Pro Built Automatics's Avatar
Go to http://www.pro-built.net/index.cfm?f...ct&productid=5 if you want to do this right the first time.
Old Dec 11, 2003 | 04:12 PM
dongalonga's Avatar
Ok what about the options on the bottom do I need any of those or are they for really hi horsepower applications? I only have a 305 TPI and I don't plan on going to crazy with the motor maybe 300hp.
Old Dec 11, 2003 | 07:17 PM
Car: '91 Camaro RS
shawn, talk to bob about the guy that did his th350.....hes nasty, and very, very cheap.....builds sick transmissions, hes in pelham
Old Dec 11, 2003 | 08:29 PM
I would add the GM HD sunshell. You only replace the rear planet if it is burnt up or the pinions or the gears have are galled. The reverse/input needs to be replaced if the band is really burnt, or if the surface where the band rides is dished, it has to be flat.
Old Dec 11, 2003 | 11:49 PM
dongalonga's Avatar
Yeah thats right I forgot about that. Bob told me about that guy before and his TH350. I'm gonna call Bob tomm. Just trying to stay away from CAP
Old Dec 12, 2003 | 03:06 PM
dongalonga's Avatar
OK the tranny dipstick says to add 1 pint. So I think I am going to put some Lucas in it and see how it is.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
