How hard is it to move a 700R4 around?
Old Nov 16, 2003 | 07:49 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I was wondering if two people could put a 700R4 into a minivan, and then lift it out. Or how else could I transport it?
Old Nov 16, 2003 | 08:21 PM
Chupakabra-King's Avatar
Car: 1989 Firebird Formula
Engine: 305 TBI
Axle/Gears: 3.08
Easy as pie . Put one in the back of my taurus ..........
Old Nov 16, 2003 | 09:16 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
i can lift one myself and carry it around
took one out of my car without a tranny jack by myself with no one's help
Old Nov 16, 2003 | 09:46 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Do you have an estimate on how much it weighs? Oh and how much would the tranny fluid add to the overall weight?
Old Nov 16, 2003 | 10:00 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
A full tranny, with full fluid, and TC on it I can't lift for long periods of time. I can move it, but I wouldn't exactly call moving anywhere near walking. I put one in the back of my escort with its high hatch, and took it out without anyone elses help. Took a lot of manuvering, and going slow but I got it done.
Now, ditch the Torque Converter, and drain the fluid and I can lift it no problem.
Two people can lift and move a filled 700r4 w/TC no problem.
Old Nov 17, 2003 | 02:39 AM
PyRo9862's Avatar
Car: 91RS
Engine: 305tbi
I'd guess 160-200 full.
If I were to move one I would call my friend who benchs 320, and is a hellova lot stronger than me
Old Nov 17, 2003 | 10:02 AM
OMINOUS_87's Avatar
My Mother and Grandmother could pick one up full and put it in a minivan if needed!
Old Nov 17, 2003 | 10:09 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
its not light. you can pick it up and move it around, but like FruityOne said, you wont want to hold it for a extended peroid of time...
when i was in high school, i kept mine stashed in my room.... the day i went to change it, i carried it down a flight of stairs, thru the house and outside to the driveway..... i felt it in my arms for the rest of the day and into the next....
id drain the fluid and pull the converter off if i ever plan to do it again...
Old Nov 17, 2003 | 11:09 AM
Morley's Avatar
200 lbs with converter installed.
Old Nov 17, 2003 | 11:35 AM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
yea, you can lift it...and fruity's prooven that it will fit in the back of a camaro too..
Old Dec 11, 2003 | 09:47 PM
FruityOne's Avatar
And, as Camaro_60108 (Joe) has proven, you can work on a 700r4 without draining the pan, OR making a huge mess!
I'm still amazed at that little though.
Old Dec 12, 2003 | 04:48 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
i picked one up, put it in the trunk of a ford tempo and took it out n carried it all over the palce (couldnt find a place to put it on the ground in the garage)
and that was with torque converter and full of fliud and i'm not a big guy in the least.
Hotrodboba400
Dec 10, 2019 07:07 PM
Dyno Don
Jan 24, 2016 08:24 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
