Pinion Pin Problem
Old Dec 16, 2003 | 09:17 PM
tgrpw's Avatar
Pinion Pin Problem
I'm having trouble getting the pinion pin out of my 12 bolt. After I take out the bolt that holds it in, it will only move an 1/8 inch and no more. I have tried taping on it with brass and it won't budge any. Does anyone have any ideas to get it out.
Old Dec 16, 2003 | 09:21 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
If the single bolt that holds the pin in place is out, and the pin's still stuck, get a brass punch, line it up, and give it one good hit. It's just stuck, nothing else in there that can really hold it in place.
Old Dec 16, 2003 | 09:36 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
did the whole pin come out?
it is about 2 1/2 inches long, with with threads for about 1/2 in. right under the hex, then a smooth pin
Old Dec 16, 2003 | 09:38 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Are you sure that the bolt didn't break partway inside the pin? This is very common, in fact Snap On makes a tool specifically to remove broken cross bolts. The bolt should have about a 2" long nipple on the end that actually locks the cross pin in place. It will be round on the end. If it isn't or part of the bolt is missing that's your problem.
Old Dec 16, 2003 | 09:39 PM
Dave Y's Avatar
Engine: 4.3L V6
heres a good one
Old Dec 16, 2003 | 09:40 PM
Dave Y's Avatar
Engine: 4.3L V6
heres a broken one
lt1z350
Sep 29, 2015 01:50 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
soarestransam
Aug 24, 2015 08:15 AM
89fast5oh
Aug 24, 2015 08:14 AM
overdriv
Aug 20, 2015 03:52 PM
