Are these gears worth the $?
Old Dec 17, 2003 | 04:09 PM
Rob116's Avatar
Car: 1986 Z-28 Camaro
Engine: 355
I've got a posi, 1le 9-bolt with 2.77 gears and I'm looking to upgrade to 3.45's. On 9bolt.com, they're selling a used 3.45 for $75. I know that I need the series three carrier to go along with it, but I'm curious as to whether the damage on this gear is merely superficial, or whether I should fork over the big(ger) bucks. All damage is due to sloppy cutting wheel work during removal. Please, have a look:
http://www.difftechnics.com/temp/rp345used1.jpg
http://www.difftechnics.com/temp/rp345used2.jpg
http://www.difftechnics.com/temp/rp345used3.jpg
Thanks!
__________________
Old Dec 18, 2003 | 11:20 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I would definately swap the gears. That swap will be like adding 100HP to the car. You could easily drop a full second of your 1/4 ET. Bang for buck it's hard to beat a gear swap.
I wouldn't use those though. Obviously the bearings were removed without a press and the damage to the gears is already done. These nicks and cuts will create stree risers that under hard use will cause the gears to explode.
db057
Apr 28, 2019 07:45 AM
GouldyGTR
Sep 7, 2015 09:05 PM
rudolphschenker
Sep 4, 2015 02:41 AM
Jetmeck
Sep 4, 2015 12:29 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
