Dana rear end.
Old Dec 19, 2003 | 05:37 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
Dana rear end.
Does GM still sell a replacement (upgrade) Dana rear end for the third gen? I saw one listed in the GM Red Book back in 1996.
Old Dec 19, 2003 | 10:48 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, their remaining stock was sold off to SLP years ago. Service parts are still available however.
Old Dec 19, 2003 | 08:38 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
The Dana rear was a Dana 44, so parts for it are really easy to find because they are used in so many 4X4 applications. It's a fairly tough rear, but if you've got traction you'de be better off with a 12-bolt or 9" because the 44 uses a fairly small ring gear.
Old Dec 19, 2003 | 10:22 PM
iroc22's Avatar
Yeah the 44 is a 8.5" ring gear which isn't too bad depending on the application and the toughest 44 is the one with 30 splines and 1 piece axles. A Ford 8.8 out of a 91-up Explorer isn't too bad of a choice either with it's 31 splines and 8.8" ring gear; however they are a c-clipped axle.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
BlackBoulder
Aug 11, 2015 11:15 PM
