clutchless trans ?'s
Old Dec 22, 2003 | 10:56 PM
Matto'85TA's Avatar
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
Ok i'm asking this for my buddy, but i am curious too.
How does a clutchless manual tranny work? Is it simply a manual with a torque convertor?
Also, could you get a 6 or 5 speed gate and adapt a auto shifter to work? Like this:
1 D N
l--l--l
2 OD R
He has a T56 right now but it is trashed, his brother has a built auto laying around that he can have. He likes the way the 6-speed console looks though. He cant afford a rebuild or a new T56 though.
Is it possible to adapt the autos shift pattern into a 6-speed pattern?
Thanks,
Matt
Old Dec 23, 2003 | 05:59 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
A clutchless manual trans uses dog faced clutch teeth in the synchronizer assemblies. These aren't streetable, because to downshift you have to rev-match the engine and trans or it won't go into gear. They are really made for full throttle dragstrip passes where every hundreth of a second counts. They are also really expensive.
The six speed doesn't have a gate. The pattern is built into the transmission. Under the shifter boot there's just a nub poking out of the trans that the shift arm bolts to. Remove the trans and there's just a big hole where the shifter used to poke through.
To swap from the T56 to an auto he will need a new console plate, and a shifter mechanism.
I'd just rebuild the T56. Does he know what's wrong with it?
Old Dec 23, 2003 | 06:15 PM
Matto'85TA's Avatar
Clutch is bad, synchros are bad, 2nd and 3rd are slipping badly. 5th is starting to slip. He simply has no money right now, the 700R-4 his brother has is for free, he eventually wants to get another T56, thats why he wants to retain the 6 speed console. He can't afford to not have the car running, its his daily driver.
Is there anyway possible to adapt the 4 speed auto shift pattern to the 6 speed gate pattern found on the console? He really, really doesnt want to hack up or remove or mess with his console at all, he just got a new one last summer.
Thanks,
Matt
Old Dec 23, 2003 | 06:32 PM
All he has to do is swap the plate in the top of the console. Again, there is no "gate" for a stick, so he'll have to install a 700R4 shifter of some kind. This may require fabricating mounting brackets if his car was a stick from the factory, or they were cut out when he went to the T56. Everything should be easily found in a junkyard for very cheap.
Make sure the shift linkage is adjusted properly and the TV cable too, or the trans will self destruct very quickly.
Old Dec 23, 2003 | 07:57 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
My friend had a clutchless manual in his old Beetle. I think it came like that from the factory.
Old Dec 24, 2003 | 11:17 AM
Matto'85TA's Avatar
Thanks a lot!
Matt
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
